Fatal error: Call undefined function virtual() /home/campingw/public_html/test php line 3
Thread begun 11/07/2013 10:37 pm by Ashjamieson | Last modified 11/27/2013 10:16 am by Jason Byrnes | 9677 views | 15 replies |
Ashjamieson
I am getting this error on all ecart pages.
Even a very simple fresh page with only an add to cart button on it.
Any ideas?
Ash
in your site definition, there is a settings on the local info tab for "Create Links relative To", change this setting to "Document" instead of using "Site" so that Dreamweaver will create the include paths using the require_once() function instead of the virtual() function.
Ashjamieson
Thanks Jason, I've made that change but still have the following coming up twice:
SCREAM: Error suppression ignored for
( ! ) Warning: require_once(/campingwithhillbilly/WA_eCart/HillbillyeCart1_PHP.php): failed to open stream: No such file or directory in C:\wamp\www\campingwithhillbilly\test.php on line 3
Also I am trying this on two different computers and having the same issue on both
send a copy of the problem page.
Ashjamieson
Have sorted problem no1 thanks Jason, now this
( ! ) Warning: session_start(): Cannot send session cookie - headers already sent in C:\wamp\www\campingwithhillbilly\WA_eCart\WA_eCart_Definition_PHP.php on line 465
Call Stack
# Time Memory Function Location
1 0.0174 341768 {main}( ) ..\test.php:0
2 0.0435 1010680 WA_eCartDefinition->GetContent( ) ..\test.php:11
3 0.0435 1010792 WA_eCartDefinition->Session_GetContent( ) ..\WA_eCart_Definition_PHP.php:70
4 0.0435 1010992 session_start ( ) ..\WA_eCart_Definition_PHP.php:465
send a copy of the test.php page please.
Ashjamieson
Problem file attached
Hi Jason, a copy of the file is attached.
Also, having chosen Australia Post as freight provider I do not get an opportunity to input the API during setup.
at line 1:
-<?php
the hyphen before the php tag is causing the error.
the australia post ratecalc service does not require an API
Ashjamieson
Now getting through to checkout ok. Then falls over telling no packages to send
Shipping Quote Failed
We're sorry
No Packages to Ship
No other error is given
Also just checked the dbase tables and nothin is being stored
add the following code to the shipping failure page, it will write the session contents including the response from the shipping provider:
<?php @session_start(); var_dump($_SESSION); ?>
