DataBase doesn't update correctly when the same UserID orders a few orders behind each other.
Thread begun 11/06/2013 3:14 am by Fritz Stickers | Last modified 11/07/2013 5:47 am by Jason Byrnes | 2101 views | 7 replies |
Fritz Stickers
When the same user orders 2 or more orders behind each other, the second order replaces the order before in the database (when it's the same user).
There is no new record for a second order from the same user. It seems like the database can not update fast enough or something like that.
It's strange.
Any suggestions please?
add the following code to your checkout success page:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params = session_get_cookie_params();
@setcookie(session_name(), '', time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
@session_destroy();
@session_regenerate_id();
Fritz Stickers
Sorry, I forgot to mention that my site is in ASP VBScript.
use this code on the checkout success page:
<% Session.Abandon %>
Fritz Stickers
I had already the WA eCart Clear Cart.
So the code now is (just before <!DOCTYPE html ....
' WA eCart Clear Cart
if ((Request.ServerVariables("Request_Method") = "POST")) then
set stickersBE = WA_eCart_ClearCart(stickersBE)
Redirect_redirStr="index.asp"'_redirStr
if (Redirect_redirStr <> "") then
stickersBE_redirStr = Redirect_redirStr
end if
stickersBE_cartAction = "ClearCart"
end if
1) The clear cart code is set to trigger on post:
you should set it to trigger an page load:
if (("" = "")) then
2) The code should not be before the doctype, it should be after the closing HTML.
Fritz Stickers
Like this, after the recordsets and DB closing ?
</body>
<!-- InstanceEnd --></html>
rsUsers.Close()
Set rsUsers = Nothing
Set rsUsers_cmd = Nothing
rsOrders.Close()
Set rsOrders = Nothing
<% Call DB_Close() %>
if (("" = "")) then
end if
end if
yes, that is correct.
