File field after edit is blank
When i go to edit a record and if I don't edit the file name, the file name gets deleted.
Please Help thanks!
Please Help thanks!
a file field cannot be given a value at page load.
add a hidden filed to your page, bind the value for the hidden filed to the image column from your recordset.
In the upload file server behavior, bind the default file setting to the hidden form field.
