FexEx Shipping Failure
Thread begun 11/02/2013 9:26 pm by bjgarner241692 | Last modified 3/18/2014 11:47 am by Jason Byrnes | 9066 views | 24 replies |
bjgarner241692
eCart 5.07
Created pages with Wizard.
Base rate calculates but when I enter shipping information and click next I get the Shipping Failed page.
I added Response Code, Error Code, Full Request and Full Reponse to the Shipping Failed page to troubleshoot.
Error Description, Response Code and Error Code are empty.
Full Request has my account number and meter number.
Full Response indicates success:
Full Response - SUCCESSSUCCESScrs0Request was successfully processed. Request was successfully processed. crs1000FEDEX_GROUNDYOUR_PACKAGINGLAXfalseA2A1SERVICE_DEFAULTPAYOR_ACCOUNT_PACKAGEPAYOR_ACCOUNT_PACKAGE5ACTUAL06.5LB3.0USD7.95USD0.0USD7.95USD0.52USD8.47USD0.0USD8.47USD0.0FUELPACKAGEFedEx Ground FuelUSD0.521PAYOR_ACCOUNT_PACKAGEACTUALLB3.0USD7.95USD0.0USD7.95USD0.52USD8.47USD0.0USD8.47USD0.0FUELPACKAGEFedEx Ground FuelUSD0.52SUCCESSSUCCESScrs0Request was successfully processed. Request was successfully processed. crs1000FEDEX_GROUNDYOUR_PACKAGINGLAXfalseA2A1SERVICE_DEFAULTPAYOR_ACCOUNT_PACKAGEPAYOR_ACCOUNT_PACKAGE5ACTUAL06.5LB3.0USD7.95USD0.0USD7.95USD0.52USD8.47USD0.0USD8.47USD0.0FUELPACKAGEFedEx Ground FuelUSD0.521PAYOR_ACCOUNT_PACKAGEACTUALLB3.0USD7.95USD0.0USD7.95USD0.52USD8.47USD0.0USD8.47USD0.0FUELPACKAGEFedEx Ground FuelUSD0.52SUCCESSSUCCESScrs0Request was successfully processed. Request was successfully processed. crs1000FEDEX_GROUNDYOUR_PACKAGINGLAXfalseA2A1SERVICE_DEFAULTPAYOR_ACCOUNT_PACKAGEPAYOR_ACCOUNT_PACKAGE5ACTUAL06.5LB3.0USD7.95USD0.0USD7.95USD0.52USD8.47USD0.0USD8.47USD0.0FUELPACKAGEFedEx Ground FuelUSD0.521PAYOR_ACCOUNT_PACKAGEACTUALLB3.0USD7.95USD0.0USD7.95USD0.52USD8.47USD0.0USD8.47USD0.0FUELPACKAGEFedEx Ground FuelUSD0.52
The odd thing though is the repeat of info. Same thing in the Full Request. The package info is duplicated.
FedEx have made a change to the XML Response format that they send back just last week.
Here is an update to the WA_eCart/WA_eCart_FedEx_PHP.php that should correct the problem
In this version we are using Pattern matching instead of trying to directly match the XML node name, hopefully that will prevent unexpected updates from FedEx like this from breaking the rate lookup in the future.
bjgarner241692
Thank you.
That seems to have fixed that issue but I still need some help.
I have selected 1 box for each piece, but the shipping amounts seem very low.
When reviewing the settings in the FedEx module it shows 1 in the Quantity field. I would expect this to be a calculation that would show the Total # of units but that calc is not available and I am not sure how to create it.
I can see the Total Weight calculation but I have a question on that as well as the formula says Qty x Weight. Will that capture the weight of each sku and total them? It seems to me that it may just calculate the first one.
Bart
when using one package for each item, you shopuld click the lightning bolt next to quantity and select the quantity cart column, the for weight click the lightning bolt again and select the weight cart column.
bjgarner241692
It is still acting as though it was just one package. No matter how many I add, it does not change the price.
eCart files attached
if i put MV Re-Charge Sleep Formula 12 - Pack 12 - 2 oz Bottles in the cart, the shipping for 1 is calculated as 8.95, 3 is calculated as 16.85, it is changing the price for the items i am trying to add to the cart?
bjgarner241692
Oops. Sent the wrong link
Ok, I see.
bjgarner241692
In pm
see PM
