Weird Layout
Hi all,
I'm using PowerGallery 2 on this page: http://www.jpengineering.co.uk/gallery.php
I was expecting the default layout but instead I get what you see on the page.
Am absolutely stumped..
Help!!!
Andrew
Hi all,
Help!!!
Andrew
trying to access the gallery css:
http://www.jpengineering.co.uk/gallery/galleries/flow/css/themes/gallery.php
gives an internal server error. This us usually a permissions issue.
set the permissions for the gallery/galleries/ folder and all files and folders under it to 755
Hi Jason,
I did that - it made no difference :(
Help - it's going to be a long weekend as it is..
Cheers
Andrew
I used File Zilla to change the permissions on the gallery/galleries/ folder and all files and folders under it to 755 and the gallery seams to be loading correctly for me.
I had to do a hared refresh in safari, to get safari working, but not in Fire Fox.
How very, very odd..
I changed the permissions on the server and checked them.
Thank you so much!
Andrew
