Determining security level for Inline CMS editing
Thread begun 10/29/2013 1:10 am by CraigR | Last modified 10/29/2013 9:57 am by Jason Byrnes | 2178 views | 3 replies |
CraigRBeta Tester
Normally a user needs administrator status in order to access inline editing of the CMS.
I have a site with several levels of security, which determine which pages or sections can be accessed
The security is such that it cascades from the top, so a Group Admin is also an Admin and a Member,
an Admin is also a Member etc. The levels are as follows, which are determined by userLevel ...
0 Group Admin
1 Admin
2 Member
None
At present, Admins and Group Admins are able to edit the CMS content, but I now want to further restrict this, so that only Group Admins have this ability
Is it possible to edit a global setting to restrict the editing ability to Group Admins ?
The only workaround I can find is to add 'true' to WA_getCMSContent() on each relevant page, which isn't a great solution for this scenario
in the WA_CMS/WA_CMS.php file there are a couple of places where the Administrator security rule is applied:
if (WA_Auth_RulePasses("Administrator")
you would need to change that to use the Group Admin rule instead
CraigRBeta Tester
I found and changed all 3 instances on this page and it works great.
Thanks Jason,
you're welcome.
