Re-populating form fields.
Thread begun 8/17/2009 9:31 pm by Groshko | Last modified 8/18/2009 11:35 pm by Groshko | 4564 views | 2 replies |
Groshko
Hello,
When I deliberately make a submission that is incorrect, the form will refresh itself with the previous entries for Full Name: , Email: , and Message: (so the user does not need to fill this in again).
The new fields which I created for the phone numbers doesn't insert the previous entry. Would anyone know why?
Many Thanks. G
Below are snippets of my code:
TOP OF PAGE BEFORE HTML
<?php require_once('WA_Globals/WA_Globals.php');?>
<?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
<?php require_once("WA_Universal_Email/mail_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WAFV_Redirect = "";
$_SESSION['WAVT_contact_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Contact_Name"]))?$_POST["Contact_Name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateEM(((isset($_POST["Email_address"]))?$_POST["Email_address"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Comments"]))?$_POST["Comments"]:"") . "",true,3);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_code"]):"") . "",((isset($_SESSION["captcha_1"]))?strtolower($_SESSION["captcha_1"]):"") . "",true,4);
$WAFV_Errors .= WAValidateRX(((isset($_POST["addblock"]))?$_POST["addblock"]:"") . "","/^$/i",false,6);
$WAFV_Errors .= WAValidateRX(((isset($_POST["seconddblock"]))?$_POST["seconddblock"]:"") . "","/^$/i",false,7);
$WAFV_Errors .= WAValidatePN(((isset($_POST["Phone"]))?$_POST["Phone"]:"") . "",true,8);
$WAFV_Errors .= WAValidatePN(((isset($_POST["Mobile"]))?$_POST["Mobile"]:"") . "",true,9);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
if ((($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST))) {
//WA Universal Email object="mail"
//Send Loop Once Per Entry
$RecipientEmail = "".($WAGLOBAL_Contact_Email_To) ."";include("WA_Universal_Email/WAUE_contact_1.php");
//Send Mail All Entries
if ("whyus.php"!="") {
header("Location: thankyou.php");
FORM AND SCRIPT CODE
<form action="" method="post" name="emailContact" id="emailContact" onsubmit="">
<div style="width:100%">
<p>
<label for="Contact_Name" >Full Name:</label>
<br>
<span id="sprytextfield1">
<input name="Contact_Name" type="text" class="inputValue" id="Contact_Name" onblur="if (document.getElementById('nameServerError')) document.getElementById('nameServerError').style.display='none'" value="<?php echo(ValidatedField("contact","Contact_Name")) ?>" size="30" />
<br><span class="textfieldRequiredMsg">A value is required.</span></span>
<input name="addblock" type="text" id="addblock" style="display:none" value="" />
if (ValidatedField("contact","contact")) {
if ((strpos((",".ValidatedField("contact","contact").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span id="nameServerError" class="textfieldServerError">Please provide your full name.</span>
<?php //WAFV_Conditional contact.php contact(1:)
<br />
<label for="Email_address" >E-mail:</label>
<br />
<span id="sprytextfield2">
<input name="Email_address" type="text" class="inputValue" id="Email_address" onblur="if (document.getElementById('emailServerError')) document.getElementById('emailServerError').style.display='none'" value="<?php echo(ValidatedField("contact","Email_address")) ?>" size="30" />
<br>
<span class="textfieldRequiredMsg">A value is required.</span><span class="textfieldInvalidFormatMsg">Invalid format.</span></span>
<input name="seconddblock" id="seconddblock" type="text" style="display:none" value="" />
if ((strpos((",".ValidatedField("contact","contact").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<span id="emailServerError" class="textfieldServerError">Please provide your email addess.</span>
<?php //WAFV_Conditional contact.php contact(2:)
<br />
<label for="Phone">Phone:<br>
</label>
<span id="sprytextfield8">
<input name="Phone" type="text" id="Phone" class="inputValue" onblur="if (document.getElementById('phoneServerError')) document.getElementById('phoneServerError').style.display='none'" value="<?php echo(ValidatedField("contact","Phone Number")) ?>" size="30">
<br>
</span>
if (!(false)) {
<span id="nameServerError" class="textfieldServerError">Please provide your phone number.</span>
<br />
<span id="sprytextfield9">
<label>Mobile:<br>
<input name="Mobile" type="text" id="Mobile" size="30">
<span class="textfieldInvalidFormatMsg">Invalid format.</span></label>
if (!(false)) {
</span>
</form>
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "none", {validateOn:["blur"]});
var sprytextfield2 = new Spry.Widget.ValidationTextField("sprytextfield2", "email", {validateOn:["blur"]});
var sprytextarea1 = new Spry.Widget.ValidationTextarea("sprytextarea1", {validateOn:["blur"], minChars:10, counterId:"countsprytextarea1"});
var sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3", "none", {validateOn:["blur"], minChars:<?php echo $WAGLOBAL_Captcha_Characters; ?>, maxChars:<?php echo $WAGLOBAL_Captcha_Characters; ?>});
var sprytextfield8 = new Spry.Widget.ValidationTextField("sprytextfield8", "phone_number", {validateOn:["blur"], useCharacterMasking:true, format:"phone_custom", pattern:"(00) 0000 0000", isRequired:false});
var sprytextfield9 = new Spry.Widget.ValidationTextField("sprytextfield9", "phone_number", {validateOn:["blur"], useCharacterMasking:true, isRequired:false, format:"phone_custom", pattern:"0000 000 000"});
</script>
In the Phone field:
type="text" id="Phone" class="inputValue" onblur="if (document.getElementById('phoneServerError')) document.getElementById('phoneServerError').style. display='none'" value="<?php echo(ValidatedField("contact","Phone Number")) ?>" size="30">
you have set the value to use the validated entries for a field named "Phone Number":
but the name of the form element is "Phone":
<input name="Phone"
The validated entries should match the form name to work properly:
value="<?php echo(ValidatedField("contact","Phone")) ?>"
Groshko
thanks
All Good! Thank-you very much Jason.
G
