Digital File Pro will not upload image files
Thread begun 10/28/2013 6:38 pm by Mysite07430650 | Last modified 11/04/2013 8:49 am by Mysite07430650 | 1709 views | 3 replies |
Mysite07430650
Hello Jason,
I have in the past used Digital File Pro to upload profile images of registered users and had it update automatically whenever the user changes their profile image. I have applied the same steps as in the recent past to a new project and found Digital File Pro is not responding. If you recall Jason, you assisted with this very same issue in the past and now, I really do not understand why it will not upload profile images.
The profile image is set to display on the user profile page. Please find a zip file containing both the Login and userupdate pages.
I should also add the uploaded images do not appear in the designated column for the profile image nor are there any uploaded images in the upload folder.
FYI: the upload folder was created manually in Digital File Pro using New Folder button option.
I appreciate your help.
Thank you.
Mysite07430650
Hello Jason,
It is sorted. I forgot to include enctype="multipart/form-data" without which upload functionality is not possible.
Digital File Pro is working.
glad to hear you got it working
HINT: if you use DW To insert the file field, it will automatically change the encoding type:
Insert -> Form -> File Field
Mysite07430650
Thanks!
It took sometime to eventually realise what the problem was, but in the end got it working.
