Fedex once again not returning rates, even though response indicates success
Thread begun 10/28/2013 2:00 pm by AlaskaTom | Last modified 11/08/2013 10:07 am by BWINJ | 3707 views | 8 replies |
AlaskaTomBeta Tester
I am using the latest WA_eCart_FedEx_PHP.php file, and recently, rates are not being returned, even though the xml response from fedex indicates success.
I am attaching the response. Could you help point me in the right direction?
Does it have anything to do the fact that the nodes in the returned xml are not prefaced by V10:, and the parsing file seems to expect that?
if (isset($WA_FedEx_params["V10:HIGHESTSEVERITY"])) $Success = (($WA_FedEx_params["V10:HIGHESTSEVERITY"] == "SUCCESS" || $WA_FedEx_params["V10:HIGHESTSEVERITY"] == "NOTE"));
Just a thought.
Thanks!
Tom
OK, I pm'd you the info
FedEx Made a change to their response XML that was causing eCart to not be able to see the returned rate, I Updated the WA_eCart/WA_eCart_FedEx_PHP.php file to correct the problem.
Jason,
Thanks so much for your help in this. I will copy that file to my other sites that use Fedex.
Fedex sure seems to be the most complex shipping api, and they seem to delight in making small tweaks to their response that break things :-)
Thanks again for your help!
Tom
you're welcome.
We changed the include file to use pattern matching instead of direct matching the XML nodes, hopefully this will prevent problems in the future when the change the XML structure again.
BWINJ
Jason,
Is the new FedEx file available? We seem to have the same problem. FedEx response is successful, but no rate is returned.
Yes, here is the updated file.
BWINJ
Thanks, it works great (again) !
