image missing in edit mode
Thread begun 10/28/2013 9:45 am by CraigR | Last modified 10/29/2013 8:44 am by Jason Byrnes | 2811 views | 5 replies |
CraigRBeta Tester
I have a page with content from PowerCMS which displays fine when not logged in.
If I log in to edit the page, the text is still visible, but any images flash on screen for a second, then disappear.
I tried deleting all of the kfm tables and using file manager to recreate them, but it didn't - it recreated wafm2 tables instead, so I may have an updated version of the extension installed now ? It didn;t fix the issue either, so I recreated the kfm tables from a backup.
CraigRBeta Tester
Pm
I updated the webassist/ckeditor/config.js file and added:
config.allowedContent=true;
to correct the problem.
CraigRBeta Tester
Fantastic, thanks Jason.
That edit fixes the problem perfectly.
you're welcome.
