Javascript doesn't always work especially in IE8
Thread begun 10/28/2013 7:16 am by tdhkfinkel424121 | Last modified 10/28/2013 7:16 am by tdhkfinkel424121 | 856 views | 0 replies |
tdhkfinkel424121
I've created a form with DataAssist and with in it I've used Java Script to do some calculations.
One section doesn't seem to work in ie8 when you fill out the whole form. But it will work if you try it by itself.
The section is the "winter storage" under the terms- you need to select a 'boat type' to get it to calcualte.
I'm not sure why this is-Can you help me?
