Pro Maps for Google only returns 10 out of 23 from recordset
Thread begun 10/23/2013 11:22 am by Rune Brynestad | Last modified 12/30/2014 2:22 pm by Ray Borduin | 8329 views | 31 replies |
Rune Brynestad
Trying to get multiple markers on a Google map via a database loop, but it returns only 10 out of 23.
I have tryed the following.
All addresses are checked to be valid google addresses.
Try to change the order of the recordset. It still returns only 10 out of 23, but not the same 10.
Deleted the _promaps_geocache.xml file to have it recreated.
Edited the last line in the searchCache function in the wagmp_map_1.php file from return ''; to return coordinates;
Cleaning the browsers cache a few times
Live URL you can look at:
http://www.jaguarenergydrink.no/her_finner_du_oss.php
Most of the map markers are located in Bergen, but there should be one in Oslo
If you need to troubleshoot directly, see private message.
Regards
Rune
i updated the searchCache function in the webassist/google_javascript/wagmp_map_1.php file from:
function searchCache(searchStr, zip) {
var xmlDoc = null;
var coordinates = '';
xmlDoc = getHTTPObject();
if(xmlDoc) {
xmlDoc.onreadystatechange = function() {
if(xmlDoc.readyState == 4) {
var x = xmlDoc.responseXML.getElementsByTagName("geocode_entry");
var geocode, id;
searchStr = searchStr.replace(/,/g, ''); //remove commas
for (i=0; i < x.length; i++) {
id = x[i].getAttribute("ID");
if (id == searchStr) {
coordinates = x[i].getElementsByTagName("geocode")[0].childNodes[0].nodeValue;
return coordinates;
xmlDoc.open("GET", "webassist/_promaps_cache/_promaps_geocache.xml", false);
xmlDoc.send(null);
} else {
return '';
return coordinates;
var xmlDoc = null;
if(xmlDoc) {
var geocode, id;
return coordinates;
xmlDoc.send(null);
} else {
return coordinates;
return coordinates;
which corrected the problem.
Rune Brynestad
Sorry Jason but I still see only the same 10. I have deleted the browser cache. See attached picture
Regards
Rune
Rune Brynestad
The problem is not solved
Were you able to find out why the updated the searchCache function did not work?
Regards
Rune
see PM
see PM
Rune Brynestad
I Can't see the PM
Where is the PM ?
If you are logged into your account, you will be able to see the Private Message section.
Rune Brynestad
I am logged into my account, but I'm not able to see the Private Message section. (See attached picture).
However, I can see that the problem is solved, but I would like to see what you did to solve it.
Regards
Rune
I'll have ray look into that, the message was:
This was an issue with the foreign language characters and sending them to the Google Geocoder.
Ray updated the promaps_geocache_php.php, and wagmp_map_1.php fie to correct the problem.
