Varying Percentages Discount Based on Quantity
Thread begun 10/18/2013 5:44 am by catnip | Last modified 10/21/2013 8:59 am by Jason Byrnes | 7709 views | 31 replies |
catnip
Hi
I am trying to add a percentage discount to our eCart5 when a user adds 3 of a certain product, BUT some of these products will offer 10% off if you buy 3 and some will offer 20% off and also 50% off....How can this be achieved? also what addition do I have to make in the database?, add another column with the percentage? ie: 20 so if this column has a value then that product has a discount applied to it?
Please can someone assist, need to have this complete over the weekend :o(
Many thanks in advance.
add a column to the cart for the discount percentage. use the decimal value, so 0.1 for 10%, etc. name the column discountPercentage
on the calculations tab, create a calculation named discountAmount as:
abs([Quantity] >= 3)?([Price] * [Quantity]) * [discountPercentage]:0
on the discounts tab, create the discount as:
trigger:
"Subtotal for any column" if the subtotal of column "discountAmount" as ">" a value of "0"
Calculation:
"Based on column subtotal"
subtotal for column "discountAmount" "plus" "0"
catnip
Hi Jason
Thanks for a great detailed explanation....but it is throwing up a syntax error in the Cart_PHP.php page on line 12
" $itmObj->discountAmount = abs($itmObj->Quantity >= 3)?($itmObj->Price * $itmObj->Quantity) * [discountPercentage]:0;//t"
Error: Parse error: syntax error, unexpected '['
what did you name the cart column? it should be named discountPercentage
catnip
Yes....that is what I named it
send the Cart_PHP.php page file please.
catnip
Sent
there is no column named discountPercentage:
//columns
$this->ID = $itemID;//n?
$this->Name = $itemName;//t
$this->Description = $itemDescription;//t
$this->Thumbnail = $itemThumbnail;//t
$this->Weight = $itemWeight;//w
$this->Quantity = $itemQuantity;//n
$this->Price = $itemPrice;//c
//calculations
on the columns click the plus button and add a new column, name it discountPercentage
catnip
Output type? Unique?
Output type van be left as text or set to number.
don't select unique.
