Show region if user is logged in
Thread begun 10/18/2013 12:55 am by Paolo R | Last modified 10/18/2013 6:50 am by Jason Byrnes | 1622 views | 1 replies |
Paolo R
Hi Guys,
I need to set up a new rule for If a user is logged in then he sees a particular region but i am struggling to understand the conditions and how to set them up.
What do the "values" "Criteria" and "compare to" so that if my user is logged in, then he will see a particular region that i specify?
Thanks,
Paolo
The Security assist wizard will create a default rule for if the user is logged in named:
Logged into <your user table>
where <your user table> is the name of your user table.
When the user logs in, the ID is stored in a session.
The logged into <your user table> rule is defined as:
Allow IF
Value: Click the lightning bolt icon and select the Session created by the login
Criteria: <> (This means Not Equal To)
Comparison: (Leave this blank)
you can then use the security assist show region behavior to show the details if the user is logged in.
