repeat region insert
Thread begun 10/17/2013 12:37 pm by mr hankey | Last modified 10/17/2013 1:18 pm by Jason Byrnes | 3100 views | 4 replies |
mr hankey
hi there,
I am trying to get a basic checklist working on the system however when you click the submit button it passes the answers into the url but does not insert to database. form code:
<form action="" method="post" name="checklist">
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_rsChecklist){
<table>
<?php do { ?>
<tr>
<td>Question: <?php echo $row_rsChecklist['QuestionName']; ?></td>
<td><?php
// RepeatSelectionCounter_2 Begin Loop
$RepeatSelectionCounter_2_IterationsRemaining = $RepeatSelectionCounter_2_Iterations;
while($RepeatSelectionCounter_2_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_2 || $row_rsChecklist){
<input name="Answer_<?php echo $RepeatSelectionCounter_1; ?>_<?php echo $RepeatSelectionCounter_2; ?>" type="checkbox" value="" />
<input name="QuestionID_<?php echo $RepeatSelectionCounter_1; ?>_<?php echo $RepeatSelectionCounter_2; ?>" type="hidden" value="<?php echo $row_rsChecklist['QuestionID']; ?>" />
<input name="clients_ClientID_<?php echo $RepeatSelectionCounter_1; ?>_<?php echo $RepeatSelectionCounter_2; ?>" type="hidden" value="" />
} // RepeatSelectionCounter_2 Begin Alternate Content
else{
<td>No records match your request.</td>
<?php } // RepeatSelectionCounter_2 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_2 && $RepeatSelectionCounter_2_IterationsRemaining != 0){
if(!$row_rsChecklist && $RepeatSelectionCounter_2_Iterations == -1){$RepeatSelectionCounter_2_IterationsRemaining = 0;}
$row_rsChecklist = mysql_fetch_assoc($rsChecklist);
$RepeatSelectionCounter_2++;
} // RepeatSelectionCounter_2 End Loop
</td>
</tr>
<?php } while ($row_rsChecklist = mysql_fetch_assoc($rsChecklist)); ?>
</table>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_rsChecklist && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
<input name="Submit" type="submit" value="1" />
</form>
// WA DataAssist Multiple Inserts
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_loopedFields = array("");
$WA_connection = $cbank;
$WA_table = "checklistanswers";
$WA_redirectURL = "login.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "question_QuestionID|Answer|clients_ClientID";
$WA_columnTypesStr = "none,none,NULL|',none,''|none,none,NULL";
$WA_insertIfNotBlank = "";
$WA_connectionDB = $database_cbank;
$WA_multipleInsertCounter = 0;
while (WA_AB_checkMultiInsertLoopedFieldsExist($WA_loopedFields, $WA_multipleInsertCounter)) {
if ($WA_insertIfNotBlank == "" || WA_AB_checkLoopedFieldsNotBlank(array($WA_insertIfNotBlank), $WA_multipleInsertCounter)) {
$WA_fieldValuesStr = "".((isset($_GET["QuestionID"]))?$_GET["QuestionID"]:"") ."" . "|" . "".((isset($_GET["Answer"]))?$_GET["Answer"]:"") ."" . "|" . "".$_GET['ClientID'] ."";
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$WA_multipleInsertCounter++;
if ($WA_redirectURL != "") {
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "1";
// RepeatSelectionCounter_2 Initialization
$RepeatSelectionCounter_2 = 0;
$RepeatSelectionCounterBasedLooping_2 = false;
$RepeatSelectionCounter_2_Iterations = "1";
I have not used webassist products for a while as I found I could not get things working and would like to use this to build a survey. if I could get this working it would help me consider upgrading to data bridge possibly but for some reason my data assist is not working with the insert?
thanks
mr hankey
reply sent, thanks Jason
mr hankey
ok I actually have this working now. I did not use the data assist repeat selector which seemed to cause the issue.
all sorted which is great. however. I need the ability to have different field types for the answers. example.
checkbox
input
select
this would be based on the question setup in MySQL. can I show one or the other depending on the question in the multiple insert?
many thanks
yes, but you would need to hand code this.
you would need a question type column then use an if statement to set the element type based on the question type.
this will require custom coding to accomplish, if you need help with setting this up, i suggest signing up for a premiere support appointment.
