File fields and Data Bridge Update Record
Thread begun 10/17/2013 7:57 am by davegw | Last modified 10/22/2013 1:06 pm by Jason Byrnes | 5204 views | 11 replies |
davegw
Just following your Digital File Pro tutorial: "Add file fields to Data Bridge insert / update pages"
I''m having trouble with the Update page section where a hidden field is placed next to the actual file field.
The hidden field is used to display the current filename in the file input box, not so?
What input ID do you use for the hidden field? Doesn't the ID have to be unique?
Everything else works except for this. My workaround is to echo the filename from the recordset under the form field if the filename exists.
Also Firefox & Chrome hide the text field next to the browse button - what happens in this case?
a file field cannot be given a value.
on the update page, if a file has already been uploaded, the hidden filed should hold the file name from the database.
the hidden field is used when no new file is uploaded. it is used so that the original file name is not removed.
the hidden field should be bound to the file name column fgrom your recordset.
in the upload file behavior, bind the default file name setting to the hidden field.
this was, if no new file is selected the server file name variable will be populated with the original file name from the hidden field.
if a new file is selected, the server file name variable will be populated with the new file name and stored in the database.
Chrome and fire fox wont display the text box that holds selected file name, but that is only visual, the file will still be sent as part of the form.
davegw
Thanks Jason
How do you name (id) the hidden field that corresponds to the file field?
I know the file field does not get a value, but it needs an id.
Perhaps you could send me some example code for the hidden & file field pair.
Cheers
Dave
I usually use the name of the file field for the ID
the name can really be anything you like as long as it conforms to javascript variable naming rules:
-Only letters and numbers can be used
-The only exception is the underscore
-the first character must be a letter
you could use:
productImage
for the file field name and ID
and then use:
originalProductImage
for the name and ID of the hidden element.
davegw
Thanks Jason - that was quick!
Now I see - the binding is the key.
As long as you bind the hidden field to the file field name, it does not matter what you name the hidden field.
Cheers
Dave
Originally Said By: davegw
Cheers
Dave
Yes, that is correct. the name is not really important as long as it is properly bound.
davegw
Hi Jason - there are 5 file upload fields for documents on a form using WA Update Record. (The record already exists)
The files upload & the filenames inserted in the table in the first update, but if I do a subsequent update , it removes all the previous filenames, then adds the current one. However if I upload using only one of the file fields, then upload another file to the SAME field, then it replaces the filename.
Any ideas?
send a copy of the page.
davegw
Here we go Jason
each of your hidden form elements needs to have the value bound to the corresponding column from the recordset.
