site, horkeyswoodandparts com started set PowerCMS created few php pages popolated them same data html pages now tried continue change pages cannot edit them click edit get error seem go into edit mode create new pages cannot get into edit add data.
Thread begun 10/15/2013 10:58 am by jerry394338 | Last modified 10/15/2013 12:38 pm by Jason Byrnes | 2859 views | 3 replies |
jerry394338
site, horkeyswoodandparts com started set PowerCMS created few php pages popolated them same data html pages now tried continue change pages cannot edit them click edit get error seem go into edit mode create new pages cannot get into edit add data. I trie
I have a client site, horkeyswoodandparts.com that I set up the CMS on. I created few php pages and populated them using the same data html pages. I have about test pages in the DB and now tried to change pages cannot edit them click edit get error seem go into edit mode create new pages cannot get into edit add data. I tried to compare working sites to see if I was missing any file and both sites appear the same. one working and one not. ?? Should I just reinstall the cms? and if what files/directories should I remove so I can do a re-install?
jerry394338
looks like some of the CKEditor files are missing from the site, it is also using an older version of CKEditor.
you can update the CKEditor Files manually.
in the webassist/ folder, rename the ckeditor folder to ckeditor_bak
On this page:
download
click the button to launch CK Builder. Select to use the Full Preset, and the Kama Skin.
Copy the downloaded CKEditor folder to the webassist folder in your site.
from the ckeditor_back folder, copy the following three files:
ckeditor.php
ckeditor-php4.php
ckeditor-php5.php
and paste them in the new ckeditor folder.
you will need to clear the browsers cache to see the updates take effect.
