free tool creating errors dreamweaver
Thread begun 10/14/2013 11:16 pm by info439002 | Last modified 11/11/2015 9:17 am by Ray Borduin | 5469 views | 8 replies |
info439002
Loaded up some free tools, the last being pay pal ones.
This now appears each time I start dreamweaver
The following JavaScript error(s) occurred
Unable to open script file "C:\Program Files (x86) Adobe/Adobe Dreamweaver\CS5\Shared\Web Assist\Framework\Framwork_shared.js" (error 3)
info439002
next error coming up
At line 168 of file
:C:\Users\users\AppData\Roaming\Adobe\DreamweaverCS5\en_US\Configuration\Shared\WebAssist\Library\WA_XML.js" XMLString has no properties
There are more appearing, basically every free toolkit is coming up, do I need to uninstall somehow web assist and re load it.
this implies more than one?
There should only be one free tools extension installed
What extensions including the version numbers are installed?
info439002
Design extender version is 1.0.8
ive uninstalled all the extensions, but the errors keep coming, and they keep changing from the ones that I listed.
I thought you said you where using free tools?
The current version of design Extender is 1.1.5
Uninstall the previous version before installing the newer one, also Reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
DSor84991691
I just installed the free tools and Google tools and now I send about 5 minutes clicking OK on all of the various WA popup errors. I even uninstalled them both, then cleared the cache. Still getting them but not as many, ie WA_memento.htm and WA_paypal.htm. Any help would be appreciated.
It sounds like you have some really old versions of webassist extensions still installed. We haven't had WA_memento in our extensions for about 5 years. What other webassist extensions do you have installed?
DSor84991691
Ray, Just those 2. They were installed today, and removed today, but I'm still getting the following popup errors. Unable to find WA_Memento.htm in the ..... and Unable to find wa_paypal.htm in the .......
Could the Memento be somewhere still part of the 2 installs (FreeTools113.mxp) (GoogleToolkit204.mxp) I installed?
O/S Win7 32
Using CS5
Yes... google toolkit is now part of free tools. Remove both and just install the latest free tools and the problem should go away.
