change date format Datepicker
Thread begun 10/14/2013 9:39 am by J7HNW | Last modified 4/16/2014 2:58 pm by Jason Byrnes | 10490 views | 18 replies |
J7HNW
Please can you tell me how to change the format. Whatever I do with Datepicker - it captures in the format YYYY / MM / DD
It is a UK site and they want it captured to the MySQL in DD/MM/YYYY
Please can you tell me how to achieve this ?
URL is http://www.mottesthighwycombe.co.uk/bookmot.php
John
the database cannot store the date in that format.
it must store the date in the yyyy-mm-dd format.
you change the format that is used to display the date on the individual pages using the date function though.
so instead of using:
<php echo $row_recordsetName['dateColumn']; ?>
to write the date to the page, use:
<php echo(date("d/m/Y", strtotime($row_recordsetName['dateColumn']))); ?>
J7HNW
Date Format
Hi Jason and thanks for your e mail
Problem is when somebody SELECTS the date from the datepickers on the form - it puts it on the form in YYYY MM DD onto the form
and this is where I Want it to view DDMMYYYY
I have searched for the code you gave me to replace in the source code on the form page - but dreamweaver cannot find this code ?
Please advise
send a copy of the page please.
J7HNW
Attached thanks Jason
theres no spry, so the format only needs to be changed for the date picker.
find this line:
dateFormat:"yy-mm-dd"
to change the format:
dateFormat:"dd-mm-yy"
but remember, the date that gets inserted to the database must be in the yyyy-mm-dd format, so code will need to be added to change the format that is passed. the code will be similar to this:
if(isset($_POST['dateField'])) $_POST['dateField'] = date("Y-m-d", strtotime($_POST['dateField']));
J7HNW
Hi Jason
Great now works perfectly on the page - you select date which is shown in UK format eg 15/11/2013
Added the PHP code you gave me to switch the date to YYYYMMDD
It now inputs all dates as 01/1/1970
MySQL field is set as DATE
Page attached again - have I done something wrong ?
John
I dont see the php code for changing the date format back to Y-m-d on your page.
add the following code at line 1:
if(isset($_POST['PreferredDate'])) $_POST['PreferredDate'] = date("Y-m-d", strtotime($_POST['PreferredDate']));
J7HNW
Thanks Jason
Added your code twice ( once for each datepicker ) and perfect. Now logs properly on page and into MySQL
if(isset($_POST['PreferredDate'])) $_POST['MotExpiry'] = date("Y-m-d", strtotime($_POST['MotExpiry']));
Only remaining problem is e mail form sent shows wrong way. DO I embed the same code into the
page waue_bookmot_3.php or into the form sent by UEMail ( Blank_4.php ) please
Kind regards and thank you for your help
John
add code to the email template file Blank_4.php to change the date format back:
if(isset($_POST['PreferredDate'])) $_POST['PreferredDate'] = date("d-m-Y", strtotime($_POST['PreferredDate']));
if(isset($_POST['PreferredDate'])) $_POST['MotExpiry'] = date("d-m-Y", strtotime($_POST['MotExpiry']));
