After putting in a plug and a 'show' for the logout on my navSSI (plugin). I have a WARNING and an ERROR.I have uploaded the whole Webassist file more than twice. But the same result occurrs.
Thread begun 10/11/2013 3:09 pm by dee | Last modified 12/13/2013 8:01 am by Jason Byrnes | 4781 views | 7 replies |
dee
Please hlep me get my pages back.
Warning: require_once(../webassist/security_assist/helper_php.php) [function.require-once]: failed to open stream: No such file or directory in /home/fmedupxf/public_html/ssi/ch-ssi-nav-fmEd--starterPage.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../webassist/security_assist/helper_php.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/fmedupxf/public_html/ssi/ch-ssi-nav-fmEd--starterPage.php on line 1
Regards Dee
dee
Thank you Jason.
Please find needed details below.
see PM
dee
Hi Jason,
Please see below.
Dee
on the index.php page, since you use require once to include the ssi/ch-ssi-nav-fmEd--starterPage.php:
<?php require_once("ssi/ch-ssi-nav-fmEd--starterPage.php"); ?>
that causes the ssi/ch-ssi-nav-fmEd--starterPage.php page to inherit the location of the index page
So this line:
<?php require_once( "../webassist/security_assist/helper_php.php" ); ?>
needs to be changes to:
<?php require_once( "webassist/security_assist/helper_php.php" ); ?>
dee
WOW!
I thank you soooo much!!
Jason does that mean all my pages are the same as the nav in my index page? If not where do I go to learn about making the nav in them all the same?
Regards
Dee
Instead of using require once to add the nav to your pages, i would suggest using plugins from framework builder:
http://www.webassist.com/tutorials/Getting-Started-with-Framework-Builder
