Captcha problem in my page
Thread begun 10/11/2013 3:07 am by Kumel | Last modified 10/16/2013 8:29 am by Jason Byrnes | 7050 views | 5 replies |
Kumel
I added google captcha in my contact form and everything went fine but not receiving emails.
If captcha is entered wrong then through verify page my page redirects to contact-error.php page where the user needs to contact form again. and if successfull then page redirect to thank-you.html page.. Pages are working completely fine. but not receiving emails thats it. Please help me as soon as possible.. thank you
Rule #1 when working with forms:
All Form Processing MUST occur on the page specified in the action attribute of the form tag.
your form tag:
<form action="verify.php" method="post" name="contactform" id="contactform">
has the action set as the verify.php page.
You would need to add the UE behavior to the verify.php page in order to send the email.
Kumel
Sir i tried adding below code to the first line of verify.php page:
<?php require_once("webassist/email/mail_php.php"); ?>
<?php require_once("webassist/email/mailformatting_php.php"); ?>
if (!isset($_SESSION))session_start();
if ((isset($_POST["Submit"]))) {
//WA Universal Email object="mail"
set_time_limit(0);
$EmailRef = "waue_contact_1";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "thank-you.html";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = "kumel619@gmail.com";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
if ($TimeRemaining < ($TotalEmails*$RealWait) ) {
$TimeRemaining = $TotalEmails*$RealWait;
$_SESSION[$EmailRef."_Total"] = $TotalEmails;
$_SESSION[$EmailRef."_Index"] = 0;
$_SESSION[$EmailRef."_Remaining"] = $TimeRemaining;
while ($RecipIndex < sizeof($RecipArray)) {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
while (($EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
if ($EnteredValue) {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
} else {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
if ($AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
if ($TimeRemaining < ($EmailsRemaining*$RealWait) ) {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
session_commit();
session_start();
$_SESSION[$EmailRef."_Index"] = $LoopCount;
$_SESSION[$EmailRef."_Remaining"] = round($TimeRemaining);
session_commit();
wa_sleep($WaitTime);
include("webassist/email/waue_contact_1.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
if ($LoopCount % $BurstSize == 0 && $CurIndex < sizeof($RecipArray[$RecipIndex])) {
$TimePassed = (time() - $StartBurst);
if ($TimePassed < ($BurstTime*60)) {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
else {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
if (!$EnteredValue) {
$RecipArray[$RecipIndex][0] = mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
$_SESSION[$EmailRef."_Total"] = 0;
$_SESSION[$EmailRef."_Remaining"] = 0;
session_commit();
session_start();
if ($GoToPage!="") {
header("Location: ".$GoToPage);
Now when i submit form from contact page i get email but if i enter wrong captcha still i get the email.
Sir can you tell me how exactly we do this?
By adding that code at the first line, that means the email will be sent before the verification takes place.
you need to have the UE code after the code on that file that verifies the captcha.
you do know that there is a webassist captcha validation that can be used, right?
By using the webassist captcha, you can have the validation and UE behavior on the same form page so you wont run into these issues.
Kumel
Yes thanks a lot. its working now..
By the way i dont have Captcha extension..
Captcha is a part of the Form Toolkit that is in Data Bridge.
See the Form Toolkit Getting Starting guide for details on using Captcha:
http://www.webassist.com/tutorials/Getting-Started-with-Form-Toolkit
