Display Sub-Categories according to chosen Main Category
Thread begun 10/10/2013 11:30 am by joerg431091 | Last modified 10/16/2013 6:49 am by joerg431091 | 13223 views | 10 replies |
joerg431091
I am trying to display certain subcategories in the sub-navigation of my products_results.php page according to what main categories was chosen in the main navigation:
So I like to have a Top navigation for all pages that have categories and drop down menus such as for example:
Main: Espresso & Coffee
Drops down to: - Espresso Machines
- Accessories
- Parts
If a user clicks on "Accessories" for example - the side navigation that will be on the products_results.php page should show only the sub categories that are available for Accessories and if the user clicks on "Parts" for example, only the sub categories available for parts should be shown on the product_results.php page.
I have a vague idea that this might be solved with relation database fields and tried to play around with it with no success.
Is there any tutorial or post that explains the step by step process of how to achieve this?
Thanks so much and best regards,
Joerg
you will need a categories and subcategories table:
categories:
categoryID - Primary Key
categoryName
subcategories:
subcategoryID - primary Key
subcategoryCategoryID - relates to the categories.categoryID column
subcategoryName
the links from the category listing should pass the categoryID as a url variable
the recordset that shows the subcategories should use the URL Variable to filter the subcategory table using the subcategoryCategoryID column
joerg431091
Hi Jason,
Thanks a lot. That makes sense and i think I am close to understand it and get it to work.
Could you give me an example for the link passing the categoryID as a url variable? I think I am making a mistake with this one.
Thanks again,
Joerg
This is an example using a URL Variable named CatID to pass category ID 12:
page.php?CatID=12
joerg431091
Awesome. That worked. Thank you so much!!!!!
glad to hear it is working.
joerg431091
Absolutely my friend. Your two replies pretty much demystified the entire Database Relationships for me and makes it much easier for me going forward. You guys are worth every single dollar we pay for your products. Thanks again.
you're welcome.
joerg431091
Hi Jason,
I have a follow up question and was hoping you could point me in the right direction:
Everything works great now that once clicked on the main navigation, the product_results.php page shows the sub categories of that particular main category that are stored in the DB.
Those sub-categories are displayed in the products_results.php page in a single recordset row using a repeat section as such:
<div class="general-block-list">
<ul class="categories">
<?php do { ?>
<li><a href="#"><?php echo $row_Recordset2['SubCatName']; ?></a></li>
<?php } while ($row_Recordset2 = mysql_fetch_assoc($Recordset2)); ?>
</ul>
</div>
So there might be 5 sub-categories shown for example. What I can't figure out is how to address the links to those individual sub-categories since I only have that one row of code.
II found a tutorial about dynamic menu navigation on webassist. Would this be a solution or is there any other way I can do this.
Thanks again for your help,
Joerg
your link code:
you can add the link to the subcat page and pass the subcat ID in the href:
<a href="subcat.php?SubCatID=<?php echo $row_Recordset2['SubCatID']; ?>><?php echo $row_Recordset2['SubCatName']; ?></a>
