i did that you told me, but it insert 5 times, but wiht out the images doesnt upload and doesnt saber in the databaxe field. i put the dataassit insert All Upload Successful, but doesn upload anything. Other problem is than if you of the fieds i dont wanto to upload a file the dataassit insert a empty field in the database...see de code:
<?php require_once('../Connections/lesmes.php'); ?>
<?php require_once("../webassist/file_manipulation/helperphp.php"); ?>
<?php require_once("../webassist/database_management/wa_appbuilder_php.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "undefined",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "790",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "../upload/blog/",
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End?>
// WA_UploadResult3 Params Start
$WA_UploadResult3_Params = array();
// WA_UploadResult3_1 Start
$WA_UploadResult3_Params["WA_UploadResult3_1"] = array(
// WA_UploadResult3_1 End
// WA_UploadResult3 Params End?>
// WA_UploadResult4 Params Start
$WA_UploadResult4_Params = array();
// WA_UploadResult4_1 Start
$WA_UploadResult4_Params["WA_UploadResult4_1"] = array(
// WA_UploadResult4_1 End
// WA_UploadResult4 Params End?>
// WA_UploadResult5 Params Start
$WA_UploadResult5_Params = array();
// WA_UploadResult5_1 Start
$WA_UploadResult5_Params["WA_UploadResult5_1"] = array(
// WA_UploadResult5_1 End
// WA_UploadResult5 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(WA_DFP_AllUploadsSuccess()){
WA_DFP_UploadFiles("WA_UploadResult1", "archivo01", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult1_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
WA_DFP_UploadFiles("WA_UploadResult2", "archivo02", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult2_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult3");
WA_DFP_UploadFiles("WA_UploadResult3", "archivo03", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult3_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult4");
WA_DFP_UploadFiles("WA_UploadResult4", "archivo04", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult4_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult5");
WA_DFP_UploadFiles("WA_UploadResult5", "archivo05", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult5_Params);
// WA DataAssist Insert
if (WA_DFP_AllUploadsSuccess()) // Trigger
$WA_connection = $lesmes;
$WA_table = "novios_fotos";
$WA_sessionName = "archi01";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "catID|archivo";
$WA_fieldValuesStr = "1" . $WA_AB_Split . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."";
$WA_columnTypesStr = "none,none,NULL|',none,''";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_connectionDB = $database_lesmes;
@session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
if ($WA_redirectURL != "") {
$WA_redirectURL = str_replace("[Insert_ID]",$_SESSION[$WA_sessionName],$WA_redirectURL);
$WA_sessionName = "archi02";
$WA_redirectURL = "blog.php";
$WA_fieldValuesStr = "1" . $WA_AB_Split . "".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"] ."";
@session_start();
$WA_sessionName = "archi03";
$WA_fieldValuesStr = "1" . $WA_AB_Split . "".$WA_DFP_UploadStatus["WA_UploadResult3"]["serverFileName"] ."";
@session_start();
$WA_sessionName = "archi04";
$WA_fieldValuesStr = "1" . $WA_AB_Split . "".$WA_DFP_UploadStatus["WA_UploadResult4"]["serverFileName"] ."";
@session_start();
$WA_sessionName = "archi05";
$WA_fieldValuesStr = "1" . $WA_AB_Split . "".$WA_DFP_UploadStatus["WA_UploadResult5"]["serverFileName"] ."";
@session_start();
<!doctype html>
<html>
<head>
<meta charset="UTF-8">
</head>
<body>
<form method="post" enctype="multipart/form-data" name="form1" id="form1">
<ul>
<li>
<label for="archivo02">File:</label>
<input type="file" name="archivo01" id="archivo01">
</li>
<li> <label for="archivo02">File:</label>
<input type="file" name="archivo02" id="archivo02"></li>
<input type="file" name="archivo03" id="archivo03"></li>
<input type="file" name="archivo04" id="archivo04"></li>
<input type="file" name="archivo05" id="archivo05"></li>
<li>
<input type="submit" name="submit" id="submit" value="Submit">
</li>
</ul>
</form>
</body>
</html>
