Sort function seems to break Template/Framework Theme
Thread begun 10/09/2013 11:35 am by eric284736 | Last modified 10/09/2013 12:22 pm by Jason Byrnes | 2380 views | 5 replies |
eric284736
Hi Jason,
I have applied a sort feature on the columns of this result page after the page was created from a template and the Framework Theme.
It appears to have broken the template, so the header (navigation) is not showing.
thx
Eric
eric284736
pm
the page was failing on resizing one of the images due to the memory limit setting on the server.
I added the following code at line 1:
<?php ini_set("memory_limit", "256M"); ?>
to increase the memory limit and fix the problem.
eric284736
Thanks Jason!!
you're welcome.
