I have followed the steps to apply a Captcha element to my form as shown in the article that shows how to validate a Captch element.
Thread begun 10/08/2013 3:41 pm by markhaynes75235 | Last modified 10/09/2013 1:05 pm by markhaynes75235 | 3424 views | 4 replies |
markhaynes75235
The server validation works because the data will not insert when the Captcha is not correctly matching the code, but the text I placed in the Validation Show If server behavior is not appearing on the page. I've moved the </label> tag that has a spry behavior so that the code is not inside that tagset. Can you help me sort this out?
Thank you!
I would need to see the code. Please send a copy of the page.
markhaynes75235
I've placed the code for the page in the Private Message area. Below is the relevant code from the form:
<li class="formItem">
<div class="formGroup">
<label class="groupHeader" for="Registration_Authorization_field">Authorization</label>
<div class="lineGroup">
<div class="fullColumnGroup">
<div class="errorGroup">
<div class="fieldPair">
<div class="fieldGroup"> <span id="Registration_Authorization_field_Spry">
<label class="checklabel" for="Registration_Authorization_field" onblur="hideServerError('Registration_Authorization_field_ServerError');"><img id="capt1" src="webassist/captcha/wavt_captchasecurityimages.php?width=200&height=50&field=Security_Code_1&bgcolor=FFFFFF&transparent=1&bgimage=&gridfreq=20&gridcolor=000000&gridorder=behind&noisefreq=20&noisecolor=1B2C5D&noiseorder=behind&characters=5&charheight=&font=fonts/MOM_T___.TTF&textcolor=1B2C5D" alt="security code" width="200" height="50" /><img src="webassist/captcha/images/refresh.png" height="18" onclick="document.getElementById('capt1').src+='&ref=1'" /><br />
<span class="requiredIndicator">&nbsp;*</span><input id="Security_Code_1" name="Security_Code_1" type="text" value="" /> </label>
if (ValidatedField('advocacysignup','advocacysignup')) {
if ((strpos((",".ValidatedField("advocacysignup","advocacysignup").","), "," . "4" . ",") !== false || "4" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Security_Code_1">Please enter the security code </span>
<?php //WAFV_Conditional newslettersignup.php advocacysignup(4:)
<br />
<span class="SecurityRequiredMsg">Enter the security code shown above</span> </span></div>
</div>
</div>
</div>
<span class="requiredIndicator">&nbsp;*</span><input type="checkbox" name="Registration_Authorization_field" id="Registration_Authorization_field" value="1" class="formCheckboxField_Standard" <?php if (!(strcmp((isset($_GET["invalid"])?ValidatedField("advocacysignup","Registration_Authorization_field"):""),""))) {echo "unchecked=\"unchecked\"";} ?> tabindex="4" />
</label>
<span class="checkboxRequiredMsg">Please agree to our terms</span> </span> <input name="Content" type="hidden" id="Content" value="please include me in your email newsletter list" /><input name="pgSrc" type="hidden" id="pgSrc" value="6" /><input id="regDate" name="regDate" type="hidden" value="<?php echo(date("Y-m-d H:i:s")); ?>" /></div>
</div>
</div>
</div>
</div>
</div>
</li>
You have 2 server validation server behaviors on the page.
you should only have 1.
you will need to remove the show if for the captcha, and remove the second validation show if behavior from the server behavior panel. The edit the first one to add the captcha validation and re create the validation show if behavior.
markhaynes75235
Thanks Jason! As always you were right. I had forgotten that all WA Server Validations are found in the same Server Validation Server Behavior. I've tested the updated live page and am awaiting the email confirmation. I'll start a new thread if I broke something there.
