a-z headings for results
Thread begun 10/07/2013 10:32 pm by Paul | Last modified 10/09/2013 10:53 am by Paul | 4591 views | 13 replies |
Paul
Can someone point me in the direction to have the results sorted like below? I have the results sorting fine, but need to add the Alphabetical category heading based on the results.
A
alpha
adam
B
banana
boat
Thanks!
this will require hand coding to accomplish.
Send a copy of your results page, and i can give further details.
i found this example through google:
http://stackoverflow.com/questions/7812097/listing-array-values-alphabetically-with-letter-heading
Paul
Here it is, Jason...
Appreciate any assistance.
line 256 starts the rrepeat region:
<?php do { ?>
change that to:
<?php $last = ''; ?>
<?php do { ?>
$current = strtolower($row_rsProducts['prodCategories'][0]);
if ($last != $current) {
echo("<tr class=\"".$WARRT_AltClass1->getClass(true)."\" >");
echo("<td>".strtoupper($current) . "</td>");
echo("</tr>");
$last = $current;
Paul
Jason,
I made the change, but it didn't change anything...was I supposed to put some reference to the Category Heading somewhere?
Thanks...
Paul
Here it is!
since you are using a grid layout, the code needed to be moved inside the repeat selection.
Paul
I saw it...thanks so much, Jason!
Paul
In the design view, I don't see anything that shows me the Category Heading...A, B, C, etc. Where do I find it in the code so that I can apply some CSS to it, simply to make it BOLD.
Thanks again...
