Timezone for mysql timestamp
Thread begun 10/07/2013 6:32 am by CraigR | Last modified 10/07/2013 8:36 am by Jason Byrnes | 2570 views | 3 replies |
CraigRBeta Tester
My client's site is hosted in the US, but is used exclusively by UK members.
One of their tables uses a timestamp to store the current date/time when a record is entered.
I have updated the php.ini to set the default timezone to Europe/London, but the timestamp in the database is still in EST.
Is there a way around this, or do I have to change the datatype to datetime and insert the current time, rather than use a timestamp ?
is the date set by using the CURRENT_TIMESTAMP default value in the MySQL database?
If so, you would nee to change the time zone on the MySQL Server:
http://dev.mysql.com/doc/refman/5.5/en/time-zone-support.html
CraigRBeta Tester
Ok, well the hosting provider won't do that, so I need to insert the date using a variable instead.
Thanks for that Jason, saves me looking for a solution in the wrong place
you're welcome.
