Why is the form not sending when submit is pressed
Thread began 10/04/2013 8:55 am by michaelf0199272 | Last modified 10/04/2013 10:10 am by michaelf0199272 | 2389 views | 4 replies |
michaelf0199272
http://www.houseofprayer-international.org/indexBoye.php
On the link shown above, when submit button is pressed, the form does not get sent. It just stayed there.
Q: Why is the form not sending when submit is pressed
*** Actual file is included
Thanks.
your button is not a submit button, it is a standard button element type. button element types do not have any inherent action to them, they are available for showing a button that you add a jquery or javascript function to.
change the button:
<input name="button" type="button" value="Submit Request" />
to a submit element type:
<input name="button" type="submit" value="Submit Request" />
michaelf0199272
Thanks Jason. I did make the changes that you suggested. When submit was pressed --- it simple cleared the fields and no email was received also it did not redirect to thankyou page.
change the name of the button to submit:
<input name="submit" type="submit" value="Submit Request" />
michaelf0199272
Once again --- thank you. It seems all is fine now.
