Hi, please am trying to create the below shipping in PowerStore using ecart to do the shipping rules.
Thread begun 10/03/2013 9:23 am by tolushayoo193471 | Last modified 10/08/2013 2:21 pm by Jason Byrnes | 6020 views | 17 replies |
tolushayoo193471
Hi, please am trying to create the below shipping in PowerStore using ecart but I don't really know how to go about it.
Delivery charge of £5.99 added to all UK Mainland orders up to 1kg.
Delivery charge of £6.99 added to all UK Mainland orders up to 2kg.
Delivery charge of £7.99 added to all other UK Mainland orders up to 25kg
The following delivery charges apply to orders over 25kg:
25.01KG - 50.00KG = £15.99
50.01KG - 75.00KG = £23.99
75.01KG - 100.00KG = £31.99
you will need a seperatre rule for each wight range.
the shipping country is stored in a session named:
eCartCheckoutForm_shipping_country
so your rule would use a combination of Session Variable Value and subtotal for any column for th triggers. For example:
"based on session variable value"
if the session variable "eCartCheckoutForm_shipping_country" has a value of "UK"
AND
"based on subtotal for any column"
If the subtotal for column "TotalWeight" is ">" "0"
AND
If the subtotal for column "TotalWeight" is "<=" "1"
Flat rate change of 5.99
the other rules will be similar, just change the weight range values and the flat rate.
tolushayoo193471
Thank you Jason for the quick response.
I've done all. But the challenge that I have now is: When I added a product that is 30kg in the basket it shipping charges me £23.98 instead of £15.99 since (up to 30kg should fall under 25.01KG - 50.00KG = £15.99) I think how it get to £23.98 was it added (Delivery charge of £7.99 added to all other UK Mainland orders up to 25kg) plus 25.01KG - 50.00KG = £15.99 together. Please how can i sort this out
Below is my rule for up to:
25kg
If session variable exists: eCartCheckoutForm_shipping_country
AND
if the session variable "eCartCheckoutForm_shipping_country" has a value of "GB"
AND
AND
If the subtotal for column "TotalWeight" is "<=" "25"
Flat rate change of 7.99
For up to 50kg
AND
AND
AND
If the subtotal for column "TotalWeight" is "<=" "50"
Flat rate change of 15.99
the up to 50 KG Rule should be:
AND
If the subtotal for column "TotalWeight" is ">" "25"
AND
tolushayoo193471
Thank you. I've changed it to the below but it charges me £7.99 for a 30kg. That £7399 is meant to be the charges for up to 25kg
AND
AND
send a copy of the cart object file and a link where i can see the problem.
tolushayoo193471
thank you
all of your rules have the condition to of the starting weight at 0
your 1 KG rule is
Total Weight > 0
And
Total Weight <= 1
then the 2 kg rule is
Total Weight > 0
And
Total Weight <= 2
the start weight for that rule should be
Total Weight > 1
the start wight for each rule should be the end weight for the rule before it.
tolushayoo193471
Thanks Jason you were right it now works. Please do you know the value that I can use for less than 1kg shipping?
thank for your time
Total Weight > 0
And
Total Weight <= 1
