PowerCMS error
Thread begun 10/02/2013 10:04 am by russb335115 | Last modified 10/02/2013 1:30 pm by russb335115 | 6694 views | 12 replies |
russb335115
PowerCMS error
I get this error when trying to load my admin user name and password, everything work great up to this point. This is at step 4 of 5 in the install
"ERROR: Failed to save the settings in the database. Please verify your database connection."
I have check the connection in Dreamweaver and it is working fine.
This error hapens if the wa_settings table falils to be created.
Run the following SQL Command using PHPMyAdmin to create the wa_settings table:
CREATE TABLE IF NOT EXISTS wa_settings (
`id` int(11) NOT NULL AUTO_INCREMENT,
`name` varchar(50) COLLATE latin1_bin DEFAULT NULL,
`type` varchar(50) COLLATE latin1_bin DEFAULT NULL,
`options` text COLLATE latin1_bin,
`value` varchar(255) COLLATE latin1_bin DEFAULT NULL,
`grp` varchar(50) COLLATE latin1_bin DEFAULT NULL,
`subcategory` varchar(50) COLLATE latin1_bin DEFAULT NULL,
`cond` varchar(255) COLLATE latin1_bin DEFAULT NULL,
`description` varchar(255) COLLATE latin1_bin DEFAULT NULL,
`variable` varchar(50) COLLATE latin1_bin DEFAULT NULL,
`weight` float DEFAULT NULL,
`spry_args` text COLLATE latin1_bin,
`spry_error` text COLLATE latin1_bin,
`help_text` text COLLATE latin1_bin,
PRIMARY KEY (id)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 COLLATE=latin1_bin;
INSERT INTO `wa_settings` (`name`,`type`,`options`,`value`,`grp`,`subcategory`,`cond`,`description`,`variable`,`weight`,`spry_args`,`spry_error`,`help_text`)
VALUES
('Site Name', NULL, NULL, 'My Site', NULL, NULL, NULL, NULL,'Site_Name', NULL, NULL, NULL, NULL),
('Serial Number', NULL, NULL, '@@serial_number@@', NULL, NULL, NULL, NULL,'PCMS_Serial', NULL, NULL, NULL, NULL),
('Image Upload Folder', NULL, NULL, 'files', NULL, NULL, NULL, NULL, 'images_folder', NULL, NULL, NULL, NULL),
('Disable Images Upload', NULL, NULL, 0, NULL, NULL, NULL, NULL, 'dis_images_upload', NULL, NULL, NULL, NULL);
russb335115
Okay that worked and it took me to the login page, when I logged the UI didn't show up and I got this message:
Table 'antronix_admin2013.pcms2_users' doesn't exist
Looks like it didn't run the db script to create the tables for some reason.
use the install_cms/scripts/db.sql file to create the CMS tables.
russb335115
I copy the code and pasted it into the SQL and ran it but got an error:
Error
SQL query:
-- Dumping data for table `optiongroups`
INSERT INTO `optiongroups` ( `OptionGroupID` , `OptionGroupName` )
VALUES ( 1, 'color' ) , ( 2, 'size' ) ;
MySQL said:
#1062 - Duplicate entry '1' for key 1
Ok, i guess, some tables did get created.
use this sql to crreate the users table:
CREATE TABLE `pcms2_users` (
`UserID` int(11) NOT NULL auto_increment,
`UserEmail` varchar(500) default NULL,
`UserPassword` varchar(500) default NULL,
`UserFirstName` varchar(50) default NULL,
`UserLastName` varchar(50) default NULL,
`UserCity` varchar(90) default NULL,
`UserState` varchar(20) default NULL,
`UserZip` varchar(12) default NULL,
`UserEmailVerified` tinyint(1) default '0',
`UserRegistrationDate` timestamp NULL default CURRENT_TIMESTAMP,
`UserVerificationCode` varchar(20) default NULL,
`UserIP` varchar(50) default NULL,
`UserPhone` varchar(20) default NULL,
`UserFax` varchar(20) default NULL,
`UserCountry` varchar(20) default NULL,
`UserAddress` varchar(100) default NULL,
`UserAddress2` varchar(50) default NULL,
`UserGroupID` int(11) NOT NULL default '1',
PRIMARY KEY (`UserID`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1;
russb335115
Okay now I get this in the web page:
Unknown column 'UserGroupID' in 'field list'
russb335115
See private section
See PM
