UK Postcode uppercase
Thread begun 10/02/2013 9:06 am by asnw0764437428 | Last modified 10/02/2013 12:53 pm by Jason Byrnes | 4622 views | 7 replies |
asnw0764437428
After creating a form in CSSFormBuilder set all the validation as required etc., except once the form is completed and tested the postcode field will only accept and validate a UK postcode if you actually type it in uppercase with the correct single space in the middle, even if the postcode is correct in lowercase. How can I get this to work regardless of whether a user types uppercase or lowercase or a space for that matter.
The UK Post code validation requires the space to be in place, the space is needed to validate the UK format.
to allow it to validate regardless of case, you can add stringtoupper. send a copy of the page and i can tell the code that will need to be changed
asnw0764437428
page attached, thanks.
edit line 12 to:
$WAFV_Errors .= WAValidateZC((isset($_POST["fieldset_group_Post_Code"])?strtoupper($_POST["fieldset_group_Post_Code"]):"") . "",false,false,true,false,true,2);
asnw0764437428
Hi Jason
Just added that snippet of code and I still have to purposefully enter the postcode as capitals?
asnw0764437428
pm'd
Remove the pry validation for the zip code, Adobe does not offer a way to edit the spry to accept lower case zip codes, you will need to use server validation for the zip code.
