trouble with a login page not inserting rows to a table on successful login
Thread begun 10/01/2013 6:07 am by CraigR | Last modified 10/03/2013 11:29 am by CraigR | 7753 views | 12 replies |
CraigRBeta Tester
I am having trouble with a login page.
I have a site with 3 levels of security, (4 if you include superadmin)
Group admin, admin and member
I have created access rules and setup page access using the access pages manager, all working ok
The problem I am having is with the login page, not behaving as I expect.
My login page is based on the one created by PowerCMS builder, with the added user level, and also contains code to insert the memberid to the login table, whenever a member logs in successfully.
Regardless of who logs in, I want to redirect successful logins to the site home page, or to the previous url if they came via a link
I thought I had it working, but it seems the insert into the login table isn’t happening.
I dont follow the logic. What is the purpose behind inserting a record on login?
CraigRBeta Tester
the client wants a popup message to appear on the home page whenever a member logs in, so that any news or other info pertinent to them - which has been added since they last logged in - is displayed in the pop-up window.
It also allows them to record which members are using the site regularly.
I can do this by recording the logins and logouts of every member
CraigRBeta Tester
PM
I updated the webassist/securoty_assist/helper_php.php file to correct the problem.
CraigRBeta Tester
thanks Jason, much appreciated.
Will check it out
CraigRBeta Tester
Hi Jason,
the login table is now updated successfully, after you updated the helper_php.php file, and everything works as it should, except that I want to redirect successful logins to the site home page, or to the previous url if they came via a link
All successful logins are ALWAYS directed to the home page, they do not go to the previous url.
If I change the parameter in the post login server behavior to TRUE, the login is then redirected Ok, but the login table is no longer appended.
I think this is because the WA_AuthenticateUser() function takes the true parameter and redirects, before the insert record server behavior is triggered.
I have tried moving the insert record behavior to within the post login server behavior, but If I do this before the WA_AuthenticateUser() function is fired, the member id session value has not been retrieved.
I don't want to edit the helper_php.php page if possible, can you advise how I can overcome this issue ?
I had to disable the redirect to previous URL to allow the insert to occur.
try adding the following code after the inert behavior:
if (isset($_GET['accesscheck'])) {
header("Location: ".urldecode($_GET['accesscheck']));
CraigRBeta Tester
unfortunately, that doesn't work either.- is it because the WA_AuthenticateUser() function is doing the redirecting ?
Just a thought, if I create a new function, and base it on the WA_AuthenticateUser() function, but simplify it so I only create the session values, (I only need $_session ['memberid']), and remove the redirect, and trigger this function AND the insert record server behavior BEFORE the WA_AuthenticateUser() fuction is run, I guess it should work ?
Seems a bit clumsy, and I would be setting the session values again when I run WA_AuthenticateUser()
