Getting date error on CachedResize_Image.php - "Warning: date(): It is not safe"
Thread begun 9/30/2013 10:47 am by Mark | Last modified 9/30/2013 11:04 am by Jason Byrnes | 1680 views | 1 replies |
MarkBeta Tester
Hi, getting the following error on image resizer, anyone any thoughts please?
Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/London' for 'BST/1.0/DST' instead in /var/www/vhosts/mydomain.com/httpdocs/webassist/caching/CachedResize_Image.php on line 283
Mark
this error occurs if the date.timezone setting in the servers php.ini file is not set.
You should contact the host to have them correct the date.timezone setting in the php.ini file.
