Add To Cart Button
Thread begun 9/30/2013 4:45 am by paulshoe379536 | Last modified 9/30/2013 9:39 am by paulshoe379536 | 2527 views | 2 replies |
paulshoe379536
Add To Cart Button
I seem to be having a problem using the "Add To Cart Button" on a results page created with DataAssist. I am using eCart v5.0.7 and Data Bridge v1.1.4. The DataAssist page manager creates a results page that encapsulates the page inside a form. When I try to use the "Add To Cart Button" wizard, I get a message that states:
"This button includes a form tag that cannot be inserted inside an existing form. Please select a new insertion point outside of any existing forms and try again."
What am I forgetting or doing wrong? I don't remember having this problem with earlier versions.
You need to remove the initial form from the page before adding the add to cart buttons.
See the following tutorial:
http://www.webassist.com/tutorials/Add-a-shopping-cart-eCommerce-Series
in the Section titeld "Delete existing Add to Cart Button"
paulshoe379536
thank you...
