Fatal error: require_once(): Failed opening required '../images/installed.php' (include_path='.:/opt/php53/lib/php') in /home3/dca/public_html/WA_Globals/WA_Globals.php on line 59
Thread began 9/28/2013 5:35 am by Jim | Last modified 5/17/2014 5:10 am by wbrooks199805 | 2257 views | 6 replies |
Jim
We started with
Here is a copy of the images/installed.jpg file converted to a php file, and a copy of the WA_Globals/WA_Globals.php file updated to use the PHP file instead of the jpg.
On Sept 25th, you sent me a link to four png images which I placed in the images folder. As well as two php files. WA_Golbals.php I found that file in the WA_Globals folder and replaced. Did not see an installed.php file in any of the folders as I added it in the same folder with the WA_Globals.php file.
The hosting company is HostGator
Not sure what step I missed
see PM
Jim
I received the wa_globals and installed.php files from the previous post. After I added them and updated the site, it took me through the CMS setup again at which point I received the above reply.
At this point I am planning to start from scratch, to see it I get a better build.
see PM
wbrooks199805
What is the answer to this?
I have the same problem while updating a page it took down the whole website. I know I read the workaround but can't find it.
wbrooks199805
This was answered in another thread.
Thank you!
