CSS Form Builder append file name on upload
Thread begun 9/26/2013 7:03 am by scott417485 | Last modified 9/26/2013 8:25 am by Jason Byrnes | 1713 views | 1 replies |
scott417485
Hi GuysI have a css form builder form which has the usual contact info, one of the fields being "company name". I have also upload file field in the form, which uploads to a folder on my server. I have set the file upload to append the file names of duplicate files incrementally, but would like to also append the uploaded files name with the "company name" field from the form i.e.: ACME-filename.pdf whereby ACME is the appended information to the uploaded pdf.Is this possible?
in the rename to filed, the existing code is:
[NewFileName]_[Increment]
click the lightning bolt icon and select the company name form element, then past the other renaming code after the dynamic data binding code for example:
<?php echo((isset($_POST["companyName"]))?$_POST["companyName"]:""?>[NewFileName]_[Increment]
