activation
Hi
Every time I restart the computer and try to use databridge I am being asked for the activation code.
I wondered what I have to do to resolve this problem.
Thank you
Yianni
Hi
Thank you
Yianni
This can happen if you change the way you connect to the internet, Hard wired to wireless or if you have VPN Software that creates a virtual network interface.
Basically the problem is the physical address for the active network connection is changing. when the physical address changes, you will need to reactivate.
