session value reset/not retained
Thread begun 9/24/2013 4:23 am by CraigR | Last modified 9/24/2013 8:53 am by Jason Byrnes | 2904 views | 7 replies |
CraigRBeta Tester
I have a mailing list with a form, on which I can select one or more recipients.
When I submit the form, the selected ids are added to an array and the imploded array values are stored in a session variable.
I then use these values as a filter on a subsequent page.
On my testing server, everything works fine.
On my client host server, the session value is always 0 on the subsequent page.
I have checked to see if the sessions are being saved properly, using the sessionTest.php file provided by Jason on this thread http://www.webassist.com/forums/showpost.php?p=23826&postcount=2 - and that looks ok
Pages attached...
URL provided on request.
Thanks in advance for any help.
instead of using :
to start the session, try using:
@session_start();
if that dos not work, I'll need to troubleshoot directly.
CraigRBeta Tester
No, that didn't work either, please see PM...
see pm
CraigRBeta Tester
OK
I fixed the issue by editing the selectrecipients.php page. I changed the following code:
if (isset($_POST["GeneralEmail"])) // Trigger
header("Location: "."/admin/mail/campaign_general.php");
exit;
CraigRBeta Tester
Thanks very much Jason.
see PM
