Blog Results and Blog Detail pages producing errors
Thread begun 9/23/2013 10:06 am by sandy170299 | Last modified 9/23/2013 10:51 am by sandy170299 | 2718 views | 6 replies |
sandy170299
I followed the tutorial at http://www.webassist.com/community/tutorials/view_tutorial.php?tutorial=Create-new-pages-from-PowerCMS-templates&accesscheck=/community/tutorials/view_tutorial.php?tutorial=Create-new-pages-from-PowerCMS-templates and have created pages based on this tutorial.
This is my query on the detail page:
SELECT C2.ContentGroup, C2.ContentPageSetOrder FROM pcms2_contents AS C1 LEFT OUTER JOIN pcms2_contents AS C2 ON C2.ContentPagesetParentID = C1.ContentID WHERE C1.ContentGroup = 'BlogPosts' AND C2.ContentPageSetOrder = %s GROUP BY C2.ContentPageSetOrder ORDER BY C2.ContentPageSetOrder DESC
When I preview the page, I get the following error:Fatal error: Cannot redeclare GetSQLValueString() (previously declared in /home/lutche5/public_html/kingsburylaw/blog-details.php:5) in /home/lutche5/public_html/kingsburylaw/Templates/insidePages.dwt.php on line 121
If I remove the code that references the function, like i had to do on the blog results page (because this function already exists in the template), I get this error instead:Fatal error: Call to undefined function GetSQLValueString() in /home/lutche5/public_html/kingsburylaw/blog-details.php on line 13
I am going to attach the blog detail page for you.
Thank you.
the code for the GetSQLValueString function should have a function_exists check around it to rpevent it from being redeclared:
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
  if (PHP_VERSION < 6) {
    $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
  $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch ($theType) {
    case "text":
      $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
      break;
    case "long":
    case "int":
      $theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case "double":
      $theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case "date":
      break;
    case "defined":
      $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
      break;
  return $theValue;
sandy170299
I'm still getting an error, even with this new code.
http://kingsburylaw.lutchenpc.com/blog-details.php?ID=3
sandy170299
see PM
The if staement:
<GetSQLValueString function code>
needs to be on both the template and the the details page, it should be on any page that uses that function. I added it to the template to correct the problem.
sandy170299
Got it - thank you!!!
