using bootstrap carousel freezes IE10 when G+ button displayed
Thread begun 9/23/2013 9:17 am by Sweens | Last modified 9/25/2013 1:10 pm by Jason Byrnes | 9497 views | 7 replies |
Sweens
Hi all
I'm using bootstrap carousel on a site and everything works fine except for IE10, when the slides weren't 'sliding' and wouldn't go beyond the second slide without clicking on the arrow. However, the carousel worked on a sub-page, using the same css ect.
So, I looked for the differences, and tracked it down to the social media buttons - specifically the google + button; if this is removed, the carousel slides in IE10, put it back in and the previous problems occur.
I'd like to include G+ (especially as it's my preferred network!) if possible. Any ideas?
please provide a link where i can see the problem.
Sweens
Hi Jason
many thanks:
NOT working properly in IE10 (with G+ social button)
http://www.rotary-ribi.org/clubsites/homepageIE.php?ClubID=1103
WORKING in IE10 (no G+ button)
http://www.rotary-ribi.org/clubsites/homepage.php?ClubID=1103
Proper browsers work fine in both<VBG>
Chris
i must be missing something. I dont see a G+ icon on this page:
and The slideshow is working?
Sweens
Hi Jason
I clicked the link and the G+ is on that page - under the 'share' link
It's an IE10 issue only - all other browsers OK;
NOT working properly in IE10 (with G+ social button )
Cheers
Chris
OK, I see the G+ tag, but the Carousel is still working for me, I cant reproduce.
You could force IE 10 to use the IE ( rendering engine as a work around by adding the following tag in the head section:
<meta http-equiv="x-ua-compatible" content="IE=9" >
Sweens
Hi Jason
The first 2 carousel images display, then the carousel stops; you can click the chevron to get the next image.
However, on the page without the G+ button, the carousel works perfectly - everything else is the same.
Cheers
chris
Try adding the meta tag i suggested from my previous reply:
