Problem Installing Powerstore cURL Error
Thread begun 9/21/2013 10:01 am by Philipp | Last modified 7/07/2015 11:56 am by Ray Borduin | 2184 views | 4 replies |
Philipp
when running the install procedure for Powerstore 4.5.3 on my server I get this error message:
"PowerStore 4 Installation Wizard
STEP 1 OF 7
This Server Diagnostic Check analyzes your server to ensure the necessary permissions and settings are enabled for PowerStore to work properly.
ERROR: All of the attributes below need to check out before you can proceed to the next step.
PHP 5.3.27-1~dotdeb.0
PHP 5.3.27-1~dotdeb.0 is installed.
GD Image Library
GD Image Library [bundled (2.1.0 compatible)] is installed.
cURL
cURL [7.21.0] is installed , however cURL was unable to post to the webassist server at https://www.webassist.com. You will not be able to complete the installation without activating through the webassist web site. .
SimpleXML
SimpleXML is installed.
Session Management
Session management works as expected.
File Permissions
Files and directories can be created."
When running this script (http://www.webassist.com/forums/showpost.php?p=87177&postcount=7) it reads: "Curl error: couldn't connect to host"
Any suggestions?
Your host is not allowing the cURL connection to be made to the webAssist servers, you will need to contact the host and have them lift the restriction for cURL connecting to the webAssist server.
Philipp
Great, now it works! Thanks for the support!
dave.l389632
Same problem on localhost
Jason do you know how to lift this restriction for a local testing server (WAMP) MySQL 5.6.17, PHP 5.5.12, APACHE 2.4.9?
Can you connect to other servers with cURL? Like this:
$ch = curl_init("http://google.com");    // initialize curl handle
    curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
    $data = curl_exec($ch);
    print($data);
I'm not a server configuration expert, but I've done a few google searches on this error. Another forum suggested:
enter - IP www.webassist.com and enter it in etc/hosts file
(I'm not sure exactly what that means, but it may be a solution)
