Can't install PowerCMS
Thread begun 9/19/2013 2:08 pm by sandy170299 | Last modified 9/20/2013 10:04 am by sandy170299 | 5012 views | 14 replies |
sandy170299
I have created a new site, created a new template, added the framework builder, and have created a new page based on the template/theme. When I go to the content area, and choose Webassist >> CMS >> Add content to PowerCMS, it doesn't take me through the installation wizard, and no admin pages are created. Did I miss a step? I was looking for the tutorial on the web site, but I couldn't find anything. Thanks!
make sure the connections folder does not already contain the following files:
installed_cms.txt
PowerCMSConnection.php
if those files already exist, the CMS Files wont be copied in, and the installation wont happen.
sandy170299
I just started with a new, clean site. We'll see what happens...
sandy170299
Isn't Power CMS supposed to create the connection name for me? I'm being prompted to name my connection right now... Where is the tutorial? I don't want to keep bugging you.
sandy170299
I started with a clean site and it's still not installing PowerCMS for me...??? Neither one of these files exist.
installed_cms.txt
You need to define the connection first, Power CMS Will create a copy of the connection you create when it installs.
Then Create a PHP page, add content to the PHP page, select that content and the go to WebAssist -> CMS -> Add Content to Power CMS.
It sounds to me like the page you have open is not saved as a php page.
sandy170299
I did save it as a PHP page, but there was no connection created at that point. That's what I missed. I created a "dummy" connection, and then it went fine. I'll try to remember that I have to have even a bogus connection created first. Thank you!
sandy170299
Ooops ... all is not well yet. I logged into my admin area, and I have no HTML editor when I click on edit. It displays the content, but as soon as I click edit, I see no content and have no HTML editor. I have not customized this editor in any way, FYI. I have not touched it. Thanks!
sandy170299
I will be upload the site to the server some time this morning. I will let you know as soon as it's residing somewhere that you can see. Thanks!
