Testing Dynamic Functions in Dreamweaver CS6
Thread began 9/18/2013 7:07 am by Mark | Last modified 9/19/2013 7:07 am by Jason Byrnes | 2321 views | 8 replies |
Mark
I'm testing dynamic functions in Dreamweaver CS6. I inserted all the proper placeholder fields and when the page loads the pictures have a question mark in them. I selected data source and chose the folder with the images to load. What am I doing wrong? Can you help me?
view source of the page what is the src for the images?
Can you send a copy of the page and a link where i can see the problem?
Mark
Jason:
I sent you a screen shot of the page in split view. There you can see the code and image source is products/. Dreamweaver sets the products as placeholders and doesn't load the images upon preview.
What would be the solution around this Jason? Any suggestions will be very much appreciated.
Thanks for your time.
Mark
Mark
Jason! I got it working. I just adjusted the image source folder and I works. Thanks.
I dont see any screen shot
Please send a copy of the page and a link where i can see the problem?
Mark
Jason:
I have another question…Sorry to be such a pain…but, I am trying to run the products from left to right. I set the float to left and made the width 30% for the div container. It still runs vertical instead of horizontal. Any suggestions is greatly appreciated.
Thanks for your time!
Mark
you need to have a containing div that is set to 100% width, and use overflow: hidden;
Then on the divs inside you can use float: left: and width: 30%;
Mark
Jason:
I'm trying to arrange these products side-by-side with a repeating region in Dreamweaver. I set the outside container to width:100% and overflow:hidden.
For the inside div, I set the parameters to: width: 30%, text-align: center, and float: left. The products seem to run vertical instead of horizontal. Adobe press has similar settings but they just don't seem to work when I try to style the container and div to their specifications. What am I doing wrong?
— Mark
I'll need to see the page live to troubleshoot.
Send a link where I can see the problem.
