SecurityAssist issues
I just installed for DW CC. When I select SecurityAssist, the dialog flashes, then disappears. cannot use it. plz advise
What extensions, including the version numbers are installed?
Do you have the latest version of Data Bridge (1.1.4)?
Have you installed the Deprecated server behaviors extension:
http://www.webassist.com/tutorials/Server-behaviors-for-Dreamweaver-Creative-Cloud
Make sure this extension is installed and that you have the latest version of Data Bridge.
Installed deprecated server behaviors panel using the instructions you provided. Data Bridge is 1.1.4.
Same problem exists
If you have other WebAssist extensions, Make sure Data Bridge was the last WebAssist extension you installed. If not, you should uninstall it and the install it again.
before using Security Assist, make sure you have a site defined:
http://www.webassist.com/tutorials/Define-a-dynamic-site-in-CS5
create a new php page in the site, and define a connection to the database:
http://www.webassist.com/tutorials/Create-a-PHP-database-connection
Does this mean that every time I install a new extension, I have to uninstall and reinstall Data Bridge?
Per your request, here are the extensions I have installed for DW
Only the WebAssist extensions are effected.
Data Bridge should be the last web assist extension installed, the other extensions order wont matter.
It seems to be working now, asking for the serial#, so I guess we've got it solved. Thanks!
glad to hear it is working.
