Having trouble updating a file field
Thread begun 9/13/2013 12:12 pm by ericbass213433382 | Last modified 9/17/2013 7:19 pm by ericbass213433382 | 2720 views | 4 replies |
ericbass213433382
Im having trouble updating the file field. At first it would rewrite with nothing but then i read your other post http://www.webassist.com/forums/posts.php?id=27157 and im using the hidden field and that works but when i pick a new image it doesnt update to the new image.
Thanks for your help.
1) The form enconding type is not set to multipart/form-data.
for a file to upload, you must use the multipart/form-data encoding type.
2) There is no file upload behavior on this page
You need to use the file upload behavior in order to upload a file.
in the file upload behaivor, bind the default file setting to the hidden form element.
3) the file upload will create a WA Uploaded Files (File Field Name) binding group. in this binding group is a variable named Server File name.
in the Insert record behavior, bind the file column to the server File name variable.
ericbass213433382
I didnt understand the last bit
Am I spose to have a insert and update record behavior on the same page. Im confused.
Sorry, I meant to say:
"in the update record behavior, bind the file column to the server File name variable."
sorry for the confusion.
ericbass213433382
Thanks!
That did it.
