Change News pods heading size
Thread begun 9/13/2013 6:40 am by Smart-FX | Last modified 9/13/2013 7:25 am by Smart-FX | 2032 views | 4 replies |
Smart-FX
Hi, how do I change the size of the heading for each pod on the right sidebar, so that they are all uniformed and not shifted to the right slightly.
in the webassist/themes/smartfx/css/crazy_styles.css file change:
.sidebar .newsArticles {
margin-bottom: 20px;
padding-left: 0;
Smart-FX
Thanks Jason,
I replaced the code which pulled everything back but now the header is thin and lost the rounded edges? http://www.smart-fx-uk.com/shop
you must have made another change also to effect the rounded corners, cause if I disable the padding-left: 0; using fire bug, it does not bring back the rounded corners. Something else was changed in addition to adding this CSS.
Smart-FX
yep, silly me, I had one to many of these little buggers {
Because i'm lazy and copied and pasted your code above hahaha.
Thanks anyways (again) :)
