Multiple SQL statement in DataAssist
Thread begun 8/17/2009 11:16 am by david.barrack304604 | Last modified 8/18/2009 1:29 pm by Jason Byrnes | 3345 views | 3 replies |
david.barrack304604
I have a case where an update needs to be done however lots of updates are being done depending on a number of conditions. For example, If # rooms needed = 3 then set rate = 100, If # room needed = 4 then set rate = 150, etc. I was planning on doing this with a number of set statements back to back but not sure I can add that custom code to the query that Data Assist sends. Does that seem like the best approach. I was also considering stored procedures but not sure if the new implementation in MySQL 5 allows for multiple statements in one sp.
You can create switch case statement to set a variable to the correct value, then bind the column to that variable in the DA Update Record server behavior.
For example, if the number of rooms needed is coming from a form element named "numberOfRooms":
if(isset($_POST['numberOfRooms'])) {
$rate "";
switch (
$_POST['numberOfRooms']) {
    case
"3"
$rate "100";
      break;
    case
"4"
$rate "150";
      break;
$_SESSION['rate'] = $rate;
make sure this code is above the Update record code. No go to the bindings panel, click the plus button and Select Session Variable set the name of the session variable to "rate"
In the update Record behavior, you can bind the rate column to the rate session variable.
david.barrack304604
location for custom code
Thank you. I was wrestling with whether to do some of this logic in SQL or php. I have never been sure where exactly to put code such as what you provided. I know it needs to be prior to where the submit logic sits but never exactly sure what the best location is. Can you please advise?
Before the Insert Record or Update Record code.
