With JavaScript if else multi conditional statement to incorporate values from 2 different menus to affect the price? This is part of a much larger form that I've been working on.
Thread begun 9/12/2013 11:57 am by tdhkfinkel424121 | Last modified 9/12/2013 1:15 pm by Jason Byrnes | 1492 views | 1 replies |
tdhkfinkel424121
I've had some help from your techs. but now I'm stuck again, I hope you can help me...
I'm trying to get the 'unitPrice' of the form to be affected by the values selected in 2 selection menus. But at the moment the form doesn't do anything.
Basically depending on the values selected in the menus Boat_Type and select1(storage type) the unit price needs to change and then be multiplied by the quantity to get the total.
Here's what I have in Javascript & the html:
<script language="javascript" type="text/javascript" />
function process3Shirts()
var boatType = new Array();
boat_type["Power"]= 'Power';
boat_type["Sail"] = 'Sail';
var storageType = new Array();
storage_type["Dry"]= 'Dry';
storage_type["Wet"] = 'Wet';
var boatType = "";
var theForm = document.forms["HSMLicenseForm_BrassyHSM_HSM"];
var selectedBoatType = theForm.elements["Boat_Type"];
boatType = boat_type[selectedBoatType.value];
var storageType = "";
var selectedStorageType = theForm.elements["select1"];
storageType = storage_type[selectedStorageType.value];
unitPrice= boatType && storageType;
var boatType = (document.HSMLicenseForm_BrassyHSM_HSM.Boat_Type.value);
var storageType = (document.HSMLicenseForm_BrassyHSM_HSM.select1.value);
//var quantity = parseInt(document.HSMLicenseForm_BrassyHSM_HSM.txt3ShirtQuantity.value);
var unitPrice = parseFloat(document.HSMLicenseForm_BrassyHSM_HSM.txt3ShirtUnitPrice.value);
//var total = unitPrice * quantity;
if(storageType == 'Dry' && boatType == 'Power'){
unitPrice = 50.00;
}else if(storageType == 'Dry' && boatType == 'Sail'){
unitPrice = 55.00;
}else if(storageType == 'Wet' && boatType == 'Sail','Power'){
unitPrice = 37.00;
document.HSMLicenseForm_BrassyHSM_HSM.txt3ShirtTotal.value = total.toFixed(2);
document.getElementById("txt3ShirtUnitPrice_show").innerHTML = unitPrice.toFixed(2) + (" /ft");
document.getElementById("txt3ShirtTotal_show").innerHTML = total.toFixed(2);
</script>
<html>
<div class="lineGroup">
<div class="columnGroup">
<label for="Boat_Type" class="sublabel" > Boat Type<span class="requiredIndicator">&nbsp;*:</span></label>
<div class="errorGroup">
<div class="fieldPair">
<div class="fieldGroup"> <span id="Boat_Type_Spry"> <span>
<select class="formMenufield_Medium" name="Boat_Type" select id="Boat_Type" tabindex="21" onChange="hideServerError('Boat_Type_ServerError');">
<option value="" <?php if (!(strcmp("", (isset($_GET["invalid"])?ValidatedField("licenseform","Boat_Type"):"")))) {echo "selected=\"selected\"";} ?>>Select</option>
<option value="Power" <?php if (!(strcmp("Power", (isset($_GET["invalid"])?ValidatedField("licenseform","Boat_Type"):"")))) {echo "selected=\"selected\"";} ?>>Power</option>
<option value="Sail" <?php if (!(strcmp("Sail", (isset($_GET["invalid"])?ValidatedField("licenseform","Boat_Type"):"")))) {echo "selected=\"selected\"";} ?>>Sail</option>
</select>
<span class="selectRequiredMsg">Please select the type of boat you have.</span> </span> </span>
if (ValidatedField('licenseform','licenseform')) {
if ((strpos((",".ValidatedField("licenseform","licenseform").","), "," . "21" . ",") !== false || "21" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Boat_Type_ServerError">Please select the type of boat you have.</span>
<?php //WAFV_Conditional license_form.php licenseform(21:)
</div>
</div>
</div>
</div>
<table border="0" width="761">
<tr>
<td width="221"><label for="WINTER_LOA_Boat" class="sublabel" ><strong>Winter Storage:</strong> <br>
Nov. 1- April 30</label></td>
<td width="167"><span id="WINTER_LOA_Boat_Spry"><span class="style59">*</span>
<input id="txt3ShirtQuantity" input name="txt3ShirtQuantity" type="text" class="formTextfield_XSmall" value="<?php echo((isset($_GET["invalid"])?ValidatedField("licenseform","txt3ShirtQuantity"):"")); ?>" size="4" tabindex="46"placeholder="00" onkeyup="process3Shirts();hideServerError('txt3ShirtQuantity_ServerError');" onBlur="process3Shirts();hideServerError('txt3ShirtQuantity_ServerError');">
Ft. LOA<span class="textfieldInvalidFormatMsg">Invalid format. Please enter the overall length of your boat.</span><span class="textfieldMinValueMsg">The entered value is less than required. You need at least 2 digets.</span><span class="textfieldMaxValueMsg">The entered value is greater than allowed .</span><span class="textfieldMinCharsMsg">Minimum number of characters not met. </span><span class="textfieldMaxCharsMsg">Exceeded maximum number of characters.</span><span class="textfieldRequiredMsg">Please enter the overall length of your boat.</span></span>
if ((strpos((",".ValidatedField("licenseform","licenseform").","), "," . "46" . ",") !== false || "46" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="txt3ShirtQuantity_ServerError">Please enter the overall length of your boat.</span>
<?php //WAFV_Conditional license_form.php licenseform(46:)
}?></td>
<td width="145"><span class="style59">*</span>$<span class="txt3ShirtUnitPrice" id="txt3ShirtUnitPrice_show">0.00</span><span class="txt3ShirtUnitPrice" id="txt3ShirtUnitPrice_show"></span>
<input id="txt3ShirtUnitPrice" input name="txt3ShirtUnitPrice" type="hidden" class="formTextfield_XSmall" value="<?php echo((isset($_GET["invalid"])?ValidatedField("licenseform","txt3ShirtUnitPrice"):"")); ?>" size="11" tabindex="47" onBlur="hideServerError('txt3ShirtUnitPrice_ServerError');">
/ft </td>
<!-- <td width="77"><input name="btn3Shirts" type="button" onClick="process3Shirts()" value="Calc. Total" tabindex="48"></td>-->
<td width="119">Total $<span class="txt3ShirtTotal" id="txt3ShirtTotal_show">0.00</span><span class="txt3ShirtTotal" id="txt3ShirtTotal_show"></span>
<input name="txt3ShirtTotal" type="hidden" class="formTextfield_XSmall" value="0.00" size="8" tabindex="49"></td>
</tr>
<tr>
<td colspan="2" align="left"><div class="errorGroup">
<label for="Storage_Type"><span class="requiredIndicator">*</span>Storage Type&nbsp;</label>
<span id="spryselect_storage_type">
<label for="select1"></label>
<select class="formMenufield_Medium" name="select1" id="select1" tabindex="50" onChange="hideServerError('Engine_Type_ServerError');">
<option value="" <?php if (!(strcmp("", (isset($_GET["invalid"])?ValidatedField("licenseform","select1"):"")))) {echo "selected=\"selected\"";} ?>>Select</option>
<option value="Dry">Dry</option>
<option value="Wet">Wet</option>
<!-- <option value="N/A">N/A</option>-->
</select>
<span class="selectRequiredMsg">Please select a storage type.</span></span>
if ((strpos((",".ValidatedField("licenseform","licenseform").","), "," . "50" . ",") !== false || "50" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="select1_ServerError">Please select a storage type.</span>
<?php //WAFV_Conditional license_form.php licenseform(50:)
}?> </div>
</div></td>
<td >
</td>
</tr>
</table>
We do not offer support for this type of custom coding here in the forums, if you want assistance in creating this, please sign up for a premiere support appointment.
