Email won't send at all
Thread begun 9/12/2013 10:07 am by mrs | Last modified 9/13/2013 6:36 am by Jason Byrnes | 3164 views | 5 replies |
mrs
I've built a contact us page with my own form on it (rather than from form builder), and I have added UE to the email page with the form on it. I have got a simple thank you page too. I have tried to get UE to work on this page for two days now and built the page three times. I started off with a dynamic to email address, but am now using a static one.
No matter what I do I can't get the form to send. I have other email functionality working fine on the same site such as registration confirmation which I have just tested. Can you tell me what I am doing wrong as this is driving me mad with frustration? The last time I built this, I don't even get the contact-thanks page anymore, but that's probably because I removed all form action info hoping the UE would handle it. I've watched your tuts on YouTube to see what I am doing wrong, but nothing stood out. I've tried printing the results of the form too, but I am getting nothing to work with, so I am sure I am doing something wrong here too.
Thank you.
Files attached.
your form tag:
<form name="contact_us" id="contact_us">
does not set a method. by leaving the method blank, it will use the GET method, but UE is expecting the for it to use the Post method.
you need to set the method to post. also, you should set the forms action, you should set the action of the form to post to itself:
<form name="contact_us" id="contact_us" method="post" action="contact-us.php">
mrs
Aha!
I had all that in place previously apart from posting to itself. I was posting to the thanks page.
Prior to this site, I have always built contact forms where I have UE on the thank you page, but in this instance I am going to add jQuery messages at a later date, so thought I'd put it in the right place to start with!
Thanks for a quick reply
Rule # 1 when working with forms:
All form Processing must occur on the page specified as the Action.
if you specify the action as another page, UE needs to go on that page.
If you specify the same page, UE can go on thee form page.
mrs
Ok, I have some confusion now that I am adding server validation. The video about it by Anna says to add the server validation code on the thank you page (confirm in her case), but the universal email code is on the contact page with the form...
Surely if everything on the page validates via spry, then the page sends the email before it gets to the server validation on the thank you page. Is that right? If so, do I add the server validation to the form page, or do I add universal email to the thank you page.
To me, it makes sense to have the validation code before the email code just in case the form isn't valid. Is that right? If so, on what page?
re read my last reply
Server validation is a type of form processing. Therefore, server validation must be applied to the page specified as the action of the form.
In the tutorial, the action of the form on the checkout page is set to post to the confirm page, that is why Anna is adding the validation to the confirm page.
Both Universal Email and Server validation are processing the form, so both need to be added to the page specified as the action in the form tag.
just make sure that the server validation code comes before the Universal Email code so that the email will only send if validation passes.
