Errors While Saving Forms
Thread begun 9/09/2013 6:17 pm by derekmparker375520 | Last modified 9/12/2013 9:55 am by Jason Byrnes | 5290 views | 11 replies |
derekmparker375520
After building a form, I save the contents and the design as presets and everything seems to work fine. If I need to make changes to the form, I do so and overwrite the presets and everything still works fine. But if I change the form more than 2 or 3 times, I start to get the attached error message (Error_When_Saving_Form.png). If I try to open the form after that, I get another error message (Error_When_Opening_Form.png). Then after closing out the page, I get yet another error message when opening the page itself (Error_When_Opening_Page.png). I have the .js file that the error message is referring to as well as the php page that the form is located on.
Any help you can give me would be great.
What version of Data Bridge are you using?
Make sure you have the latest version installed, version 1.1.4. if you have a previous version, make sure to uninstall it from the extension manger before installing the newer one.
the middle error will happen if you edit the form and remove a element that had validation, you can either ignore the error error, or let DW Search for the spry reference and delete it.
derekmparker375520
Good call, I had 1.1.3. I updated to 1.1.4 and it seems to have corrected it. Only now when I press submit it doesn't do anything. I have the page attached.
derekmparker375520
Thanks, it's in the private message.
see pm
derekmparker375520
Sorry about that, see below.
the spry validation for the company field was set to use the email format:
var Company_Spry = new Spry.Widget.ValidationTextField("Company_Spry", "email",{validateOn:["blur"]});
i edited that to no format:
var Company_Spry = new Spry.Widget.ValidationTextField("Company_Spry", "none",{validateOn:["blur"]});
also, in the server validation, the captcha validation was set to use the wrong session variable:
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security"])?$_POST["Security"]:"")) . "",((isset($_SESSION["captcha_Security"]))?strtolower($_SESSION["captcha_Security"]):"") . "",true,8);
I edited that to use the correct one:
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security"])?$_POST["Security"]:"")) . "",((isset($_SESSION["captcha_Security_2"]))?strtolower($_SESSION["captcha_Security_2"]):"") . "",true,8);
derekmparker375520
You're the man, it works perfectly. I'm having the same issue with another site so I'm assuming it's the same sort of thing. Is there a way to easily search for it? I tried inserting the code that I've found on the forums used to find which validations are failing but that didn't do it.
send me the details for that page, and i'll look into it.
